RTX Roundtracer Extreme all-in-one measuring system integrates roundness, contour, and surface roughness measurement functions on a single platform to save time and improve productivity. Advanced CNC machine utilizes speed, accuracy, and operability at the highest level to measure a variety of workpieces with various geometries, such as camshafts and bearings
Mitutoyo America
marketing@mitutoyo.com
Booth #135215
CMM-Manager expands its 5-axis probing capabilities, adding support for Renishaw Revo infinitely indexable scanning probe. QxSoft offers CMM-Manager software with plug-n-play interface to any CMM.
QxSoft, LLC
www.qxcmm.com
Booth # 135435
The US Made Microstar 320-185 CMM was developed as the ideal companion to the Renishaw High-performance PH20 5-axis touch trigger probe system. The rigid dual-beam bridge construction, mechanical bearings, and stronger motors and drives enable the 320-185 to produce inspection cycles 2-3X faster than typical CMMs with conventional probes.
Helmel
www.helmel.com
Booth #135001
The fully automated, 3-axis, multi-sensor measurement systems are easy to use and offer high-end functionality at an entry-level price. The motorized zoom, touch probe, probe rack compatibility, and large measuring capacity (up to 16″ x 12″ x 8″) make this system an ideal choice for getting precision measurements.
Vision Engineering
www.visioneng.com
Booth #135323
Stop by the Keyence booth, #135226 in the East building, to see our wide-range of inspection technology including the IM Series Instant Measurement System. It is a place-and-press measurement system that automatically measures parts in just seconds. See for yourself just how quick and easy this tool can make your inspection process.”
Keyence Corporation of America
https://www.keyence.com/
Booth #135226, 236633, and 338017
MobileCollect offers unlimited mobility for capturing your measurements in real-time, with 100% accuracy, at the press of a button. Setup is straightforward; link multiple transmitters with a receiver, and install multiple systems in close proximity without concern. Over 100+ gage brands and 3,500+ gage devices are supported, allowing you to choose the best gage devices and software application for your situation.
MicroRidge
www.microridge.com
Booth #135413
The new USAVS Joystick 3.9mm portable videoscope provides features and functions that allows you to complete your most challenging inspections. Responsive articulation and the clear imaging provide the details required to make good quality decisions. The 1.5-meter-long probe provides more than adequate length to complete many aviation borescope inspections.
USA Borescopes
www.USABorescopes.com
Booth #135936
The L.S. Starrett Co. will be demonstrating the latest in quality control inspection technology. Supporting Industry 4.0, IoT and the Digital Factory, attendees can see for the first time at a live major event, demonstrations of automated wireless measurement data capture and transmission from handheld wireless/ electronic gages via the new DataSure® 4.0 Wireless Data Collection System, or from Vision Systems and Optical Comparators via integrated software.
The L. S. Starrett Co.
www.starrett.com
Booth #135044
Seeing is Better Than Believing. See how industrial computed tomography is changing metrology. We can help a diverse mix of manufacturers expedite products to market with a thorough 3D analysis of the interior and exterior of parts.
Nel PreTech
https://nelpretech.com
Booth #135429
Please visit Fowler High Precision to discover our full line of state-of-the-art metrology systems including Micrometers, Calipers, Indicators, CMMs, Optical Comparators, Height, and Bore Gages. See our new robot attachments and Bluetooth connectivity in action. Let us help you improve your quality and productivity! Visit us at Booth #135838.
www.fowlerprecision.com
Booth #135838
Combining the high speed scanning of the REVO with the ease of use CMM-Manager Software from QX Software, Masters Precision brings high speed and ease of use to the shop floor. 500mm per second scanning on an affordable platform, now makes high speed scanning inexpensive.
Master Precision
www.mastersprecision.com
Booth #135833
Magnescale will feature an exposed, non-contact magnetic linear encoder with 5 nanometer resolution and IP67 environmental protection rating for unmatched performance in harsh environments.
This high accuracy exposed magnetic encoder improves machine accuracy and reliability, and is available up to 6.3 meters with Fanuc, Siemens, Mitsubishi and Yaskawa signal protocols.
Magnescale Americas
https://www.magnescale.com/en
Booth #135319
Z-Mike Pro provides absolute accuracy, reliability and repeatability for dimensional measurements of outer diameter, ovality, taper, TIR, runout and effective cutting diameter. Leading manufacturers rely on Z-Mike’s +/-0.5 mm accuracy and +/-0.13 mm repeatability to deliver superior quality products.
NDC Technologies (BETA LaserMike)
www.ndc.com/betalasermike
Booth #135436
Gain control of your 3D metrology processes with the premier universal software platform. With PolyWorks|Inspector™ you can control tool or part dimensions, diagnose and prevent manufacturing and assembly issues, guide assembly building through real-time measurements, and oversee the quality of assembled products by using portable metrology devices and CNC CMMs.
PolyWorks by InnovMetric
www.innovmetric.com
Booth #135080
As the only hand-sized portable 3D scanner in the market so far, Scantech’s SIMSCAN 3D scanner, also German Red Dot Award Winner, is especially designed for 3D scanning narrow and hard-to-reach areas. Scantech is one of the earliest high-tech companies starting to research and develop handheld 3D visual measurement devices across the world.
Scantech
www.3d-scantech.com
Booth #135845
Mahr Inc.’s Millimess 2000W(i) and 2001W(i) Digital Comparators offer innovative features including touch display, an inductive measurement system and integrated wireless connectivity. They combine practical, reliable operation and maximum precision with added probe linearization for static or dynamic measurement tasks.
Mahr Inc.
www.mahr.com
Booth #135810
With the easy-to-use CT technology of Zeiss Metrotom 1, anyone can efficiently perform complex measurement and inspection tasks with just one scan. Measure and inspect hidden defects and internal structures that cannot be detected with tactile or optical measuring systems. With its small footprint, the CT scanner fits easily into your metrology lab.
Zeiss Industrial Quality Solutions
zeiss.com/metrotom-1
Booth #135502
Are you at IMTS to look for new CNC machines? Chances are that you’ll see a touch probe in the tool rack. Touch probes can really multiply CNC productivity. On-machine touch probes can identify workpieces, align them precisely to the machine tool axes, and even take mid-cycle measurements. They can play an important role in unattended machine operation.
The Q-Mark part number TM4-6053-C is its most popular machine tool stylus. Weighing in at less than 5 grams, it’s 50.0 mm long from its stainless steel base to the center of its 6.0 mm diameter ruby ball, and uses a 4.5 mm diameter ceramic stem.
Q-Mark
https://cmms.com
Booth #135501
Plex Systems, a Rockwell Automation company, is excited to announce its new Quality Management System with modular enhancements including Advanced Quality Management, Labor Workforce Management, and Product Introduction and Management. Take the lead in quality with Plex’s new modularity strategy to maximize your quality management system. Visit Plex at Booth #133000.
Plex Systems
www.plex.com
Booth #133000
