By Tim McMahon
Lean manufacturing (or thinking) can help companies gain a competitive advantage. The core idea is to maximize customer value while minimizing waste (and not compromising productivity).
Lean is more than a specific tool, management technique or software package. Lean is creating and implementing processes that are highly responsive to customer demand. Lean paves the way for delivery of high quality products and services, at the right location, at the right time, all in a cost effective manner.
Ideally, the new processes optimize all parts of the value chain so that you do more with less—less labor, capital, and time.
Lean Thinking is comprised of five fundamental principles that provide a framework for creating an efficient organization:
Specify Value – End-use customer view
Identify Value Stream – Activities that create value
Flow – Make value flow
Pull – Respond to customer demand
Perfection – Zero waste
Lean is Customer First; what is value in the eyes of the customer? What features do they want? When do they want them and at what price? Without this information, how can you design your ideal system?
This value needs to flow from raw materials through to the consumer. This is Just In Time manufacturing (JIT), producing what the customer wants when they want it!
Next you strive for perfection, improving everything that you can about the product and process.
This is done by all within your organization, Lean values respect for people, and involves everyone to help meet customer value.
Lean is a systematic way to see the inefficiencies and address these to grow the business. To make processes more efficient and move closer to the value stream, we use lean thinking.
There is a handy acronym for knowing the eight types of waste: “Tim Woods.”
Transportation
Transporting items or information that is not required to perform the process from one location to another. While the product is moving, no value is added to it.
Inventory
Inventory and information queued-up between people and processes that are sitting idle not being processed.
Motion
Excess movement by people or equipment only consumes time and resources without producing value. People, information or equipment making unnecessary motion due to workspace layout, ergonomic issues or searching for misplaced items.
Waiting
Idle time created when material, information, people, or equipment is not ready. No value is added while people wait for product to process or product waits for people or machines.
Over-Processing
Performing any activity that is not necessary to produce a functioning product or service. Doing more than what is necessary to generate satisfactory value as defined by the customer.
Overproduction
Waste from producing product that is not currently needed or product that is not needed at all.
Defects
Products or services that are out of specification that require resources to correct. Defects are the result of executed processes that did not produce value.
Skills
The waste of underutilized intelligence and intellect commonly referred to as behavioral waste. When employees are not effectively engaged in the process.
Lean rules provide the guidance to improve, explaining the “why” behind the tools. For everyone in an organization, these rules help structure activities, connect customers and suppliers, specify and simplify flow paths, and bring improvement through experimentation.
The principles of the Lean used to provide value can be summarized into four basic rules:
Activity Rule – Specify all work to content, sequence, timing, and outcome.
Connection Rule – Customer-supplier connections must be direct & unambiguous.
Pathway Rule – Pathways for product/service must be simple & direct.
Improvement Rule – Improvements are made using scientific method (PDCA) at place of activity (Gemba) under the guidance of a teacher (Sensei)
These principles are the building blocks of a Lean production system. They allow organizations to gain maximum efficiency so everyone can contribute at or near his or her potential. When the parts come together the whole is much, much greater than the sum of the parts.
In most scenarios, Lean can offer manufacturing companies:
Higher-quality products with fewer defects and rework
Lower levels of inventory
Higher levels of stock turnover
Fewer breakdowns of equipment and processes
More output
Better delivery performance
Greater profits
Happier customers
Enhanced and stronger relationships with vendors
More engaged workers
All these benefits are even more critical in the pandemic with the major disruptions to manufacturing.
For me Lean is a thinking methodology for running your business. The goal is to grow the business by adding value to the customer, eliminating waste, and engaging all employees in this process. Lean is about learning to see opportunities and continually improving them.
