the latest products to help you improve your manufacturing process
Visit the Quality Show to learn about the latest technology and processes for measuring.
See the products exhibitors will be displaying this year.
Harness the Power of Automation
Part of the R-series, this turnkey solution features the MetraSCAN 3D-R mounted on a collaborative robot (Cobot), perfect for small and medium businesses looking for simple robotic deployment. It offers a powerful optical CMM scanner with high-performance optics, ease of use and the best operational and budgetary flexibility.
Creaform Inc.
855-939-4446 | creaform3d.com | Booth #1510
GAGEtrak
From simplified to comprehensive, there’s a version of GAGEtrak to fit your needs and budget. Choose streamlined management of gages, calibrations and procedures with GAGEtrak Lite or opt for extended capabilities with GAGEtrak Pro including MSA and crib management for complete gage life cycle tracking and beyond.
CyberMetrics Corporation
800-777-7020 | https://cybermetrics.com | https://gagetrak.com | Booth #820
Diatest BMD Plugs
Check bore size, TIR, Min/Max and more with high resolution Diatest BMD plugs. With up to .000010” resolution they fit inside machines or can be used alongside a Cobot thanks to our standard tool holder designs. Use the readings to sort/pass/fail parts or offset the machine.
Diatest
847-550-4024 | www.diatestusa.com | Booth #1300
Mahr Marsurf CM Mobile
MarSurf CM mobile, a portable optical surface metrology tool, includes a 16-bit high-dynamic-range camera that improves data density by 5x and low light sensitivity by 256x, ensuring optimum contrast for highly dynamic surfaces while maintaining robust performance and low noise-to-signal ratio. It also offers the highest acquisition speed and highest resolution confocal measurements.
Mahr Inc.
www.mahr.com | 401-784-3392 | Booth #1208
Mitutoyo America Quick Vision Pro
Quick Vision Pro: The QV Pro Series features newly developed StrobeSnap vision measuring function that speeds up run time by approximately 35 to 45 percent regardless of measurement position or continuity while achieving higher throughput and high-precision measurements. Quick Vision Pro Series machines have high-performance technologies that improves 3D non-contact.
Mitutoyo America Corporation
630-820-9666 | www.mitutoyo.com | Booth #1308
Phillips Precision Universal Spring-Load Chuck
Filling a void in work holding options for rings and spherical part inspection, Phillips Precision introduces a new Universal Spring-Load Chuck to the arsenal. This tool may be the solution for hard to hold parts that previously required custom setups. Now, measure a large size range with one-handed operation (no accessary tools required).
Phillips Precision, Inc.
508-869-0373 | www.phillips-precision.com | Booth #818
QI Macros for Excel
QI Macros® for Excel is the most powerful, easiest to use, most affordable SPC package on the market. Highlight your data in Excel, select the chart… that’s it! The software creates the chart automatically. QI Macros can even choose the chart for you.
Download a free 30 day trial: www.qimacros.com/trial
QI Macros for Excel
888-468-1537 | www.qimacros.com | Booth #1715
ZEISS Industrial Quality Solutions
These industries are highly competitive and rapidly changing. ZEISS experts will be on hand to share their knowledge on flexible and future-proof solutions. The ZEISS learning theater presentation, “Accelerating Your Quality Assurance Validation Process,” will be held on the exhibit hall floor Wednesday, October 25, 2-2:30pm.
zeiss.com/metrology | 800-327-9735 | Booth #1108
