From the editor
Darryl Seland
The edges often do not provide safety, stability, or an opportunity for perspective.
You Can’t Fall Off the Middle
Darryl Seland
I recently heard the phrase, "You can't fall off the middle." For me, it almost immediately fit into my advocacy for balance. I have often thought that if we take two extremes (i.e., the polar opposites of the same issue or two seemingly diametric approaches to the same task), where we want to be is right in the middle. Ask yourself if you would rather see a subzero temperature day with blizzard conditions or a swelteringly hot day with no shade or breeze as a reprieve from the power of a blazing sun? Not much of a choice, but it would probably get you thinking about how great a seventy-two-degree day with a nice breeze would feel.
The phrase is frequently applied to making decisions and navigating conflict. Unlike the edges, which represent extremes, volatility, and peril, the middle is the place of safety, stability, and moderation. When you are in the center, you have the widest margin for error, whereas the edges—intellectual, emotional, or physical—provide a direct path down.
In conflict resolution, "falling off" happens when one takes a radical side, leading to an over-correction or a total breakdown of relations. The middle represents a space of objectivity where one can observe the facts without emotional entanglement. By staying in the middle—acting as a mediator or simply maintaining neutrality—you cannot "fall" because you are not participating in the volatile oscillations of the opposing sides. The middle is not, as some believe, a weak position; it is a strategic vantage point that remains anchored while others struggle at the precipice.
In this balanced state, one is grounded in core values, making it impossible to be swept away by fleeting drama or external pressure.
In a metaphorical sense, the "middle" represents the mundane, the consistent, or the "average." While society often glorifies being on the cutting edge—the highest performer or the most innovative—those positions are precarious. A "falling-off" in performance, quality, or popularity is a common fear in business or art. However, when you operate in the middle, you are not subject to the rapid, disastrous descents that follow extreme peaks. The middle represents a sustainable foundation—the floor rather than the roof.
In personal life, the middle is synonymous with emotional regulation. The "edges" are rage, euphoria, panic, or despair. When we act from a place of emotional extremism, we are prone to making mistakes, hence "falling." The middle is the center of calm, often cultivated through mindfulness or simply choosing not to react immediately. In this balanced state, one is grounded in core values, making it impossible to be swept away by fleeting drama or external pressure. You are anchored in your own truth.
In essence, you cannot fall from the middle because you have already reached the ground. It is the solid, safe, and sustainable place to build a life, a business, or a relationship.
However, the middle can have a negative connotation. Ever heard the term “stuck in the middle?” In his analysis of realities in manufacturing, particularly for mid-size manufacturers, Randy Carr writes, “Mid-sized manufacturers are increasingly being squeezed on one side by large companies with the budgets and expertise needed to succeed in today’s fast-paced environment, and on the other by smaller, more entrepreneurial producers who are better able to adapt, specialize, and grow to meet the continually evolving needs of customers.”
Find out the three realities these manufacturers need to accept in order to shift their businesses from surviving to thriving in Randy’s article, “Manufacturing Reality: Stuck in the Middle.” And check out our profile of this year’s Quality Rookie of the Year, Sainyam Arora, and everything else we have to offer in this month’s Quality.
Enjoy and thanks for reading!
Opening Background Image Source: James P. Hohner Jr.
Darryl Seland is the editorial director of Quality magazine.
