Case Study
V&S
H2 Deck By Bold Name
h2 xxxxxx
H1 xxxxxx
h2 xxxxx
The standout feature of the system was its ability to hold tight tolerances—an essential requirement when working with aviation components. By Emily Rapp
Handheld CMM
Helps MRO Shop Enhance Inspection
JETAIR SUPPORT specializes in the inspection and maintenance of aviation components, including life-limited parts that are crucial to aircraft engine performance. Given the high stakes of their work, precision, accuracy, and efficiency in measurement and inspection processes are critical.
The Challenge
Before integrating the Keyence XM-5000 Handheld CMM, JETAIR SUPPORT relied on manual hand tools such as calipers, micrometers, and height gages to measure critical features like thickness, height, roundness, and concentricity. While these traditional tools were effective, they had limitations in terms of speed, repeatability, and the ability to verify discrepancies identified by customers. JETAIR SUPPORT needed a solution that would enhance accuracy while improving efficiency in their inspection workflow
The Solution: Keyence XM-5000
JETAIR SUPPORT first learned about Keyence’s metrology products at an aviation convention. Recognizing the potential benefits, they decided to invest in the XM-5000 Handheld CMM to assist their inspectors and technicians in achieving greater precision. The standout feature of the system was its ability to hold tight tolerances—an essential requirement when working with aviation components.
Since implementing the XM-5000, JETAIR SUPPORT has leveraged its capabilities for:
  • Measuring the thickness and height of interior and exterior features
  • Ensuring roundness and concentricity of critical engine parts
  • Double-checking key measurements when discrepancies arise
  • Generating automated reports to support inspections and compliance
Quality Q-CAST podcast ad: "Precision, Process, People," feat. Michelle Bangert, Darryl Seland.
The Results
Over the past two years, JETAIR SUPPORT has seen significant improvements in their inspection process, including:
  • Increased Precision – The XM-5000 provides highly accurate measurements, helping JETAIR SUPPORT meet tight tolerances with confidence.
  • Enhanced Efficiency – The system speeds up the measurement process, allowing for faster inspections without compromising quality.
  • Cost and Error Reduction – By improving accuracy and repeatability, the XM-5000 has minimized errors and helped reduce operational costs.
  • Regulatory Compliance – The system’s automated reporting ensures that JETAIR SUPPORT can provide credible documentation to meet industry standards.
Additionally, the implementation process was seamless, thanks to support from a local Keyence specialist and comprehensive training resources provided with the purchase.
When created using an accurate ATOS 3D scanner, digital twins enable the ability to make reliable decisions based on insightful data and perform comprehensive analysis to improve quality control, geometric dimensioning, planning efficiency and processes through simulation.
JET AIR team with a 3D scanner, laptop, and an aerospace component.
Digital assembly is a digital twin application allowing manufacturers in remote locations to share 3D scan data to digitally assemble parts and simulate the finished product before incurring costs.
Man scanning a complex metal part with a handheld device; laptop shows its 3D model.
Future Plans and Advice
JETAIR SUPPORT is so impressed with the XM-5000 that they just purchased a second system a little over a year after adopting their first.
When asked what advice they would give to others considering the XM-5000, their response was simple: “Buy it. We just purchased our second. Once you see the system in action, you will easily recognize how useful it is for your inspection process.”
The ability to measure the average diameter while also reporting roundness—a capability they previously lacked—has been particularly beneficial.
By adopting the Keyence XM-5000 Handheld CMM, JETAIR SUPPORT has transformed its inspection process, achieving higher accuracy, efficiency, and reliability. The system has proven to be a game-changer in their workflow, solidifying its value in the aviation industry.
Images Source: Keyence
Emily Rapp, Technical Marketing Engineer III, Quality and Metrology Systems, Keyence Corp. www.keyence.com
