H2 Deck By Bold Name
h2 xxxxxx
H1 xxxxxx
h2 xxxxx
Test & INspection
The Hidden Cost of “Good Enough” Physical Testing. By James Fusco, Albano Bala, and Noah Morgan
When
Repeatability Breaks
Test & INspection
Headline
Introduction: The Assumption
In many laboratories, confidence in physical testing is based on the assumption that results are consistent and that, if a method works once, it can be repeated. However, shifts in operator technique, environmental conditions, or instrument calibration can undermine that confidence. The problem often goes unnoticed until discrepancies start surfacing between shifts, sites, or production batches. When “good enough” testing becomes standard practice, the real costs appear in rework, rejected lots, and lost credibility. As quality teams face growing pressure to defend data integrity, understanding where repeatability breaks down is becoming critical, not only for compliance, but also for maintaining trust in every reported result.
The Illusion of Repeatability
Paint laboratories rely on standardized methods, trained operators, and controlled conditions. When the same tests are run daily and results remain within specification, repeatability is assumed. Over time, consistent pass results reinforce confidence in the testing process, and the measurement system itself is rarely questioned.
Early signs repeatability is declining
Loss of repeatability usually develops gradually and is easy to overlook.
Common indicators include:
- More frequent test reruns
- Small differences between operators or shifts
- Results drifting closer to specification limits
- Increased discussion over whether results are “real” or “noise”
Individually, these issues appear minor. Together, they suggest weakening measurement control.
Measuring paint vs. measuring the test system
Laboratory results reflect more than the paint alone. Each result includes the effects of the instrument, operator technique, sample preparation, and test conditions. When the measurement system is not routinely evaluated, changes in results may be misattributed to the product rather than the test itself.
How “acceptable” results can hide variability
Results that fall within tolerance are often accepted without further review. However, this practice can mask growing variability in the measurement system. Over time, a wider range of results becomes normal, creating a false sense of stability. When failures finally occur, the root cause is often long-term measurement drift rather than a sudden product issue.
Where Inconsistency Creeps In
When two labs disagree, it rarely means either one is wrong. More often, they’re working from different assumptions, different environments, or different routines. Consistency requires more than calibrated equipment — it requires shared discipline.
Different Instrument Parameters
Results from two labs can disagree simply because the test instruments have different parameters, even when everyone follows the same written method. Variations in contact area, probe or indenter shape, illumination/measurement angles, sample preparation, or sensor placement change the stress, field, or visual differences in the coating during measurement, so the property being “measured” is not identical between devices.
Equipment drift and calibration gaps
Over time, laboratory instruments naturally drift due to wear, contamination, or environmental exposure. When calibration intervals are extended or verification checks are reduced, this drift can go unnoticed. Results may still appear consistent, even as accuracy and repeatability decline.
Operator technique and interpretation
Even with standardized methods, small differences in operator technique can influence results. Variations in sample preparation, timing, pressure, or visual interpretation introduce operator-dependent variability. These differences often remain hidden until results are compared across technicians or shifts.
Environmental and procedural variation
Changes in temperature, humidity, lighting, or test setup can affect measurements, particularly across different shifts or locations. Minor procedural differences, such as mixing time, conditioning period, or cleaning practices, compound this variability. When not tightly controlled, these factors contribute to inconsistent results that are difficult to trace.
Unless the above factors are standardized or explicitly harmonized, interlaboratory comparisons will show apparent disagreement that is actually due to these differences rather than true material variability.
The Hidden Costs of Inconsistency
The hidden costs of inconsistent testing and quality data extend far beyond minor operational inefficiencies and often go unnoticed until they begin to affect profitability and customer trust. When measurement results are not repeatable, organizations are forced into cycles of rework, troubleshooting, and material waste, driving up production costs and diverting resources from innovation and improvement. Inconsistent data also slows product validation and approval processes, delaying market entry and creating uncertainty for customers who rely on dependable performance and documentation. Over time, weak or conflicting results complicate internal audits, regulatory reviews, and third-party assessments, making it difficult to defend product claims and process controls with confidence. This exposes organizations to reputational risk, potential compliance issues, and strained client relationships, ultimately undermining long-term competitiveness and business stability.
When “Good Enough” Isn’t Enough
In most quality assurance testing, small, incremental variations in measured data often seem insignificant on their own, yet they compound as materials move through manufacturing, application, and evaluation processes. In coating systems, slight differences in surface preparation, film thickness, cure schedules, or environmental conditions can accumulate, creating misleading performance data. One real-world example of this is how a coatings manufacturer approved a new coating system after routine adhesion tests met minimum pass/fail requirements. However, minor inconsistencies in surface cleaning and cure time were overlooked. Months later, widespread adhesion failures appeared, leading to peeling and delamination across multiple installations. A root-cause investigation showed that compounded variation had weakened interfacial bonding, despite “acceptable” lab results. While the original testing was technically passable, it failed to provide meaningful insight into real-world durability. This case illustrates the gap between meeting specifications and achieving reliable, predictive measurement.
Rebuilding Confidence in Your Results
As organizations confront the operational and financial consequences of inconsistent testing, rebuilding confidence in results requires a more structured, systemwide evaluation of repeatability. This begins with assessing how equipment, methods, and personnel each contribute to variation through crossoperator studies, instrument alignment checks, and method audits. Environmental influences and historical data trends help reveal hidden drift that accumulates over time. From there, standardized training, documented procedures, and reference materials ensure operators interpret and execute tests uniformly. Many labs also turn to experienced testing partners who provide benchmarking, identify performance gaps, and help realign measurement systems so results become reliable rather than reactive.
Conclusion: From Data Defense to Data Confidence
Strengthening repeatability allows organizations to move beyond defending questionable data and toward making faster, more confident decisions. When instruments, procedures, and operators are aligned, repeatability becomes a strategic advantage, reducing rework, accelerating approvals, and reinforcing customer trust. A proactive, systemlevel approach ensures that small variations are addressed long before they become production issues or audit findings. Ultimately, the goal is not simply to meet specification requirements, but to create a testing ecosystem where results are stable across shifts and sites, enabling laboratories to rely fully on the data that drives critical business outcomes.
